I’m working on large projects that require anywhere from 2-6 details on a layout. Is there a script, command, or plugin that is available that would allow me to batch change the display mode of the details on a current page or all pages at once?
I currently need to click into the detail to set the display mode for that detail and this becomes very tedious when I need to change many details in a set.
The match properties do not accomplish this task and this would be a great addition for layouts.
Any help is greatly appreciated!
Willem
(Willem Derks)
March 9, 2021, 3:12pm
2
See if the attached script works for you:
set_all_details_mode.py (1.7 KB)
import Rhino
import scriptcontext as sc
2021 03 09 script by Willem Derks (willem@onepush.nl) per request:
https://discourse.mcneel.com/t/batch-change-script-or-command-to-change-the-detail-viewport-display-mode-in-layouts/120014
def set_detail_displaymode(detail_id,mode_name):
rs.UnselectAllObjects()
rs.SelectObject(detail_id)
rs.Command('-Detail Enable ', echo=False)
rs.Command('-SetDisplayMode Viewport=Active Mode={} '.format(mode_name), echo=True)
rs.Command('-Detail EnablePage ', echo=False)
def get_current_layout_details():
current = sc.doc.Views.ActiveView.MainViewport
current_id = current.Id
current_details = []
detail_ids = rs.ObjectsByType(32768)
for detail_id in detail_ids:
geom = rs.coercerhinoobject(detail_id)
if geom.Attributes.ViewportId == current_id:
current_details.append(detail_id)
return current_details
def set_all_details_displaymode():
#get displaymode names
mode_names = [mode.LocalName for mode in Rhino.Display.DisplayModeDescription.GetDisplayModes()]
mode_name = rs.ListBox(mode_names, 'choose mod eto set details in')
if not mode_name : return
for view_name in rs.ViewNames(return_names = True, view_type=1):
rs.CurrentView(view_name)
detail_ids = get_current_layout_details()
rs.EnableRedraw(True)
-Willem
This is fantastic!! Thank you kindly it works like a charm.
