Change all detail view display modes
I’m working on a drawing that has about 9 sheets that each have a shaded detail viewport or two. While annotating I’d like to be able to make all viewports wireframe display mode to speed things up. My python code is not working, I can change the typical 4 views and the layouts to wireframe, but I can’t seem to figure out how to change the detail viewports display mode. Any thoughts?
import Rhino
def RunCommand( is_interactive ):
    views = rs.ViewNames(return_names=False, view_type=1)
    for view in views:
        if view == rs.IsLayout(view):
            print view
            details = Rhino.DetailNames(view, False)
            for detail in details:
                rs.ViewDisplayMode(detail, 'Wireframe')
    rs.Redraw()
if( __name__=="__main__" ):
    RunCommand(True)
Hi Jake,
I think you will need some RhinoCommon to do this:
import Rhino
import scriptcontext as sc
def SetDetailsToWireframe():
    display_mode = Rhino.Display.DisplayModeDescription.FindByName("Wireframe")
    if display_mode:
        page_views = sc.doc.Views.GetPageViews()
        for page_view in page_views:
            details = page_view.GetDetailViews()
                if detail.Viewport.DisplayMode.Id != display_mode.Id:
                    detail.Viewport.DisplayMode = display_mode
                    detail.CommitViewportChanges()
            page_view.Redraw()
– Dale
Dale,
I’m not very familiar with rhinocommon, so I’m working my way through this. I added a few prints for debugging and found that ‘details’ was not always a list so added an ‘if’ statement and was able to make it down to the last ‘for’ statement. Any reason I’m getting the error below?
import Rhino
    print display_mode
    if display_mode:
        print page_views
            if isinstance(details,list):
                print "its a list"
            else:
                details = [details]
            page_view.Redraw()
    RunCommand(True)
Message: 'Array[DetailViewObject]' object has no attribute 'Viewport'
Traceback:
line 18, in RunCommand, "C:\Users\jcp\Documents\Working Myfiles\Rhino\Python\AllVPortWireframe_dale.py"
line 23, in <module>, "C:\Users\jcp\Documents\Working Myfiles\Rhino\Python\AllVPortWireframe_dale.py"
Hi Jake,
My prior example didn’t have much error checking, such as verifying a page view had details. This one is a little better.
import Rhino
def SetDetailsToWireframe(debug):
    # Find the wireframe display mode
    if display_mode:
        DebugPrint(display_mode, debug)
        # Get all of the document's page views
        if page_views:
            # Process each page view
                DebugPrint(page_view, debug)
                # Get all of the page view's details
                if details:
                    # Process each page view detail
                        DebugPrint(detail, debug)
                        # If the detail's display mode is not wireframe...
                            # ...set it to wireframe.
                    # Redraw the page
                    page_view.Redraw()
def DebugPrint(object, debug):
    if object and debug:
        print object
SetDetailsToWireframe(True)
Dale, thanks for the updated code, it worked great. I couldn’t help but add a little improvement (with the help of @NavArch) to make it a bit more robust by selecting a display mode from a listbox.
import Rhino
    modes = rs.ViewDisplayModes()
    setmode = rs.ListBox(modes, "Select mode")
    display_mode = Rhino.Display.DisplayModeDescription.FindByName(setmode)
    if display_mode:
        if page_views:
                if details:
                    # Redraw the page
                    page_view.Redraw()
        print object
This is very helpful.
I’m not familiar with python… could someone please explain a way to change the script so that it only affects the current layout?
I often produce drawings with over 10 viewports on one page.
Thanks!
@JVN, I’m still not very good at scripting, but I’ve learned to cobble things together with guidance from forums and references. I think if you look at https://developer.rhino3d.com/samples/rhinocommon/determine-active-viewport/ you may be able to figure out how to make the changes only to the current layout.
Hi @JVN,
How about this?
import Rhino
def SetActiveLayoutDetailsToWireframe():
    view = sc.doc.Views.ActiveView
    if isinstance(view, Rhino.Display.RhinoPageView):
        wireframe_id = Rhino.Display.DisplayModeDescription.WireframeId
        wireframe_mode = Rhino.Display.DisplayModeDescription.GetDisplayMode(wireframe_id)
        for detail in view.GetDetailViews():
            if detail.Viewport.DisplayMode.Id != wireframe_mode.Id:
                detail.Viewport.DisplayMode = wireframe_mode
        view.Redraw()
– Dale
This is great, thank you. I’m just trying to get that list box to pop up, so I can choose the display mode.
Here is our script that generates a list box of view modes. You’ll have to mash this up with the script @dale posted.
import Rhino
    if display_mode:
        if page_views:
                if details:
                    # Redraw the page
                    page_view.Redraw()
        print object
Hi Dale,
This script is super helpful! I have almost no scripting knowledge but I have successfully adapted it so it changes to Shaded instead, however I am trying to do the same for Technical but I am getting an ‘object has no attribute’ error… I am assuming that the word Technical is wrong in itself? Would you be able to show me how to get it to work?
Hi @Hebe,
How about this?
import Rhino
    tech_id = Rhino.Display.DisplayModeDescription.TechId
    tech_mode = Rhino.Display.DisplayModeDescription.GetDisplayMode(tech_id)
        if detail.Viewport.DisplayMode.Id != tech_mode.Id:
            detail.Viewport.DisplayMode = tech_mode
    view.Redraw()
– Dale
@dale
Thank you so much! this works perfectly!
