Basic SubD appears faceted?
Hi, can anyone help me? I’m currently modelling quite a simple 5 sided shape, I’m using soft crease on the corners, for some reason the outline I’m given is very smooth, but the object I can see is ‘softly’ faceted?
Check the Render Mesh setting.
no effect sadly as that’s what google came up with
when I convert to NURBS its fine, but when trying to work with non CAD people, all they see is a jagged mess when you’re trying to make changes to the design
Are you exporting the SubD as mesh?
only to NURBS
How does your ToNURBS output look like?
tonurbs is fine, its just when working in subd
Could you share this 3dm file? BTW, could you run the SystemInfo in the command line, copy and past the popup contents here? Thanks.
It’s more apparent with flat shading.
System Info
Rhino 9 SR0 2025-5-13 (Rhino WIP, 9.0.25133.12305, Git hash:master @ b4245b0c20169dc325cfed119b4f8b1fb8cc339f)
License type: Commercial, build 2025-05-13
License details: Cloud Zoo
Expires on: 2025-06-27
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 9.0.5
Computer platform: DESKTOP
Standard graphics configuration on OpenGL
Primary display: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 1-26-2025 (M-D-Y). OpenGL(4.6.0 NVIDIA 572.16)
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 1-26-2025 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-26-2025
Driver Version: 32.0.15.7216
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Program Files\Rhino 9 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 9.0.25133.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25133.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25133.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25133.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25133.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.25133.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25133.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25133.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
subd-issue.3dm (79.3 KB)
Rhino 8 SR18 2025-4-10 (Rhino 8, 8.18.25100.11001, Git hash:master @ 5d157e876c23ece334d9c8666b8513ffc6d4a98d)
License type: Commercial, build 2025-04-10
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Primary display and OpenGL: AMD Radeon RX 6700 XT (AMD) Memory: 12GB, Driver date: 4-25-2025 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 25.5.1.250417
> Accelerated graphics device with 7 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-25-2025
Driver Version: 32.0.21001.9024
Total Video Memory: 12243 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25100.11001
This is due to the render mesh of the SubD. Use the SubDivide command to increase the density of faces and you’ll get a smoother render mesh. There’s no way outside of the render mesh controls for Raytraced display and the Render command to increase the density of polygons in the render mesh for a SubD in shaded display modes. Note, a low face count like this will never look as smooth as it would with a few more subdivisions even if capturing rendered images. If you are sending 2D images of the SubD for review you can try maxing out the SubD mesh slider for the render meshes and use the Raytraced display mode or the Render command. For any other shaded mode, you’ll need to SubDivide.
What Brian said is correct, at present. We are looking at different options to increase SubD display and analysis density for v9:
https://mcneel.myjetbrains.com/issue/RH-86272
