Hi there!
I’m having trouble figuring out how to bake the colours from the script onto different layers so I can then edit materials in rhino. Thanks!
Brick wall gradient working file.3dm (659.7 KB)
Brick wall gradeint.gh (64.8 KB)
Hi there!
try eleFront?
Thank you for your reply!
I’ve downloaded the elefront plug-in but am having trouble with figuring out which components connect where, the bake component is showing as red
Brick Wall Gradient_With Elefront.gh (69.7 KB)
There are a couple things going on here:
You choose which of these modes, using the Color Source. To achieve what you are after, you want to set the Color Source to By Object (option 3 above), and then provide the color itself into the Object Colour.
If you want to do this in eleFront, you do that here:
Bake Objects component you’ll want to make sure the tree of your Attributes matches the tree of your geometry (this should be hinted at in the red error message)Some more info:
https://elefront.via.inc/docs/eleFront%20Primer/Attributes
https://elefront.via.inc/docs/eleFront%20Primer/Bake#bake-with-attributes
