Can a grasshopper object be baked automatically? I am designing with grasshopper, and I want bake a object once I change the parameters, rather than bake it manually.
I believe that’s not the way you want to go. Making changes in GH often takes tens of seconds and baking would make it even worse.
Download Elefront plugin and use its Bake component. Maybe it would allow you to bake automatically, but mainly you can bake fast with single click, straight into layers and you can also set the Bake to overwrite previous Bake results so you don’t have to delete them manually.
Cheers,
Jonas
Thank you a lot. The Elefront is great. It helps a lot.
