Axo/iso production
#1
Hello Friends
What is the best way to make an AXONOMETRIC version of a VisualARQ model? Usually in Rhino I rotate, then shear, to produce an AXO, but it appears that VisualARQ elements don’t transform. Any suggestions? For example, can VisualARQ elements be converted into Rhino solids to produce a final axo?
Best,
Don
#2
Hi Donald, if you explode the VisualARQ objects they will turn into Rhino solids. (But you will lose their parametric properties).
#3
Perfect, thanks!
Exploded axonometric view
#4
Will there ever be a non-destructive way to do this?
#5
@Prehabitat I hope so. I know @vittorio wrote some code to generate AXO views. Perhaps he can add more details and tell you if it works with VisualARQ objects without exploding them.
#6
Perhaps we’ll see it in V6… its useful for architecture which I understand the user base has been growing… though perhaps most of the arch users take their model to archived/Revit for docs?
