Avoid warnings
I have a problem with the Boolean Split function in grasshopper. It always works, but the code freezes until I hit “ok” on the warning below. How do I set the tolerance so that I don’t see this warning? It slows down my process.
Hi - as far as I remember, it uses the Rhino document’s tolerance and so you can change it there.
The better way, I suppose, would be to make sure that the geometry that you create is accurate enough to avoid this issue.
