bbalbastre
(B. Balbastre)
March 21, 2022, 10:24am
1
Hi everyone,
I am struggling to create a python script within GH to make snapshots automatically from Rhino baked geometries to .png files.
I found this amazing script made by @AndersDeleuran which solves this problem. However, in the case I have, geometries are placed in different Rhino views and my lack of scripting knowledge makes me impossible to edit the code.
This is the normal way of using Kangaroo with the timer, to see the movement on screen:
However, if you want to produce and save an animation, you can do this…
The input I have is a bunch of curves placed in a row within an individual rectangle which represents the area to print in a png. What I would like to do is to create an individual png file of each rectangle.
What I thought is to create a script, which inputs would be these rectangles, capable of selecting each rectangle, make an individual zoom selected, and use Ander’s script to print the screenshot in a png file with a defined name.
Would anyone help me with this topic?
I really appreciate it!
Regards!
This might get you started with that part:
bbalbastre
(B. Balbastre)
March 21, 2022, 6:36pm
3
Hi @AndersDeleuran ,
That script was very helpful, thank you. I am still struggling with the coding since something is wrong but I am not capable of finding the mistake:
import Rhino as rc
import ghpythonlib as gh
import os
def zoomSelected(geometryBases):
""" Zoom to geometryBases ala Grasshopper Zoom function, inflate to zoom out """
bb = rc.Geometry.BoundingBox.Empty
for gb in geometryBases:
bb.Union(gb.GetBoundingBox(False))
bb.Inflate(0)
avp = rc.RhinoDoc.ActiveDoc.Views.ActiveView.ActiveViewport
result = avp.ZoomBoundingBox(bb)
return result
def captureViewportToFile(width,height,directory,fileName):
""" Captures the Rhino viewport to an image file (png). """
# Check that the directory exist
if not os.path.exists(directory):
print "Folder does not exist"
else:
# Concatenate the directory, file and extension strings
filePath = directory + "\\" + fileName + ".png"
filePath = filePath.replace("\\","\\\\")
# Setup the capture settings
wh = " _Width=" + str(width) + " _Height=" + str(height)
sga = " _Scale=1 _DrawGrid=No _DrawWorldAxes=No"
abg = " _DrawCPlaneAxes=No _TransparentBackground=No "
capSettings = wh + sga + abg
# Capture the image to file
if rc.RhinoApp.RunScript("-ViewCaptureToFile " + filePath + capSettings + "_Enter",echo=False):
# Print message
print "Captured: " + os.path.normpath(filePath)
Vector_length = gh.components.ListLength(Geometry)
if Calculate:
for i in range(Vector_length):
zoomSelected(Geometry[i])
captureViewportToFile(Width,Height,Directory,FileName[i])
The script worked with one geometry but not with a list of them. The error says TypeErrorException: iteration over non.sequence of type Guid.
Does anyone know about this error?
The input here are two rectangles
Thanks in advance
bbalbastre
(B. Balbastre)
March 22, 2022, 10:33am
4
I made some changes and it finally worked!
I cannot still understand why the previous script was not working. If someone can detect the mistake I really appreciate to let me know it.
Here is the solution:
import Rhino as rc
import os
vector_length=gh.components.ListLength(Geometria)
if Toggle:
for i in range(vector_length):
gb = Geometria[i]
solido = gb.GetBoundingBox(False)
Result= avp.ZoomBoundingBox(solido)
if not os.path.exists(Directory):
else:
filePath = Directory + "\\" + FileName[i] + ".png"
wh = " _Width=" + str(Width) + " _Height=" + str(Height)
Thank you @AndersDeleuran for your help. That script helped me a lot!
By the way, is there a command to crop the capture or to print just a selected rectangle area?
Regards!
