Automated fitting (rhino/grasshopper)
Is there any way to change the type of fitting between the pieces in an automated way? I want to make a combination between the original fitting and a fitting like the example in the image below, making the external sheets and the internal slats have a tear, one fitting into the other. exactly between the red slat and the purple sheet where there is a green mark, this on all the sheets.
cone-lamp.3dm (18.9 MB)
cone-lamp.gh (1.8 MB)
Hey @Eduardo6,
See if tweaks here help:
Notes:
  1. I changed the Rhino document tolerance to 0.001.
  2. I had to make some ‘new’ mid planes (actually slicing through center of vertical shapes).
  3. I corrected number of boundary surfaces generated for the vertical (stems) elements.
Best,
RC
I need to keep the cutting list with the order of the pieces (A0, A1, A2
 B0, B1, B2
 just like before).
And the internal pieces disappeared, or am I doing something wrong?
How do I define the thickness? I will be cutting a 3mm MDF sheet
They were taken out for a bit - the data was split to manage intersections between red and blue parts, which pertained to your question - I then assumed the internal rings didn’t need anything done - correct me if wrong.
You can retrieve the structure back - check/replace this:
Not sure - I didn’t see anything defining that in your grasshopper file, so I measured it from the model - turns out to be 3mm, so I used that value for notching the pieces:
I need the inner rings.
some errors appeared here for me
uh oh - bummer - that’s because I’m on Rhino 8 - I’ll save you a version 7 one. The inner rings are there, though - no problem.
Apologies for delay - here it is - no errors on this side - check it:
cone-lamp-R7.gh (1.8 MB)
Hello
I got an error here, I believe it is something related to the lack of a plugin.
How can I change the name of the parts to the same as before, like the image below?
thanks
Definitely not a plugin - it’s a bug - it’s an area component that got transferred over from R8 - it happens. Replace with a new area component.
You should be able to right-click that white box and get rid of it with ‘delete placeholder’ - if this option doesn’t show up I think you need to delete the group box thing first:
Hello
The area error no longer appears, but these points in the image below appear.
How do I make the list of names the same as the original file, separated by A and B and their respective parts?
Thank you
Those points are the area centroids. Simply turn off the preview for the area component so they’re not visible?
Though things stayed in the same place, the modified tree structure seems to affect it.
A quick ‘work-around’ here is to match the tree to your original tree:
The section of the file I helped with starts prior to your original C# ‘mesh explode’ part (your white group), which outputs the data structure now matched.
I hope this helps - apologies for the back-and-forth.
Cheers
Hello, sorry for so many questions, I don’t know much about Grasshopper, but I want to learn.
As soon as I opened the file, several errors appeared, but when I added the “Area” component, the errors disappeared, but the result is also not appearing in Rhino.
the inner rings are also gone.
Hi @Eduardo6 !
It seems you were using an example file to learn from, which is great! Keep it up!
This little annoyance is due to the Rhino 8 components that aren’t supported by R7 Grasshopper/MAC version - just in case I saved the file again and threw an ‘old’ area component there:
If for whatever reason it doesn’t work, simply add your own area component as you did before.
Anyway,
Oops, GH geometry preview was left off, in the future look to the upper right-hand corner and make sure the ‘white/green cylinder’ is turned off:
They shouldn’t be - I see them here - I have saved the file again with previewed geometry turned on; lastly just reconnect to your OpenNest process (I left it disconnected so the file loads fast, then connect + wait):
Make sure you open the latest file, here:
cone-lamp-R7_REV.gh (1.8 MB)
Best,
RC
