Hi, I managed to set selected Rhino Views active, when I try to do the same thing to snap shots, I have this 2 troubles.
I can’t get the snapshot obejct using a similar way.
I am not sure when I push the view info things will work as the same
Hello- you can always fall back on the Rhino command
rs.Command (“_-Snapshots Restore " + chr(34) + “Snapshot name” + chr(34) + " Enter Enter”)
Hi Hali - I don’t know what the rest of the script is doing, but you should be able to keep track of the snapshot name (your ‘opt-1’ - where does that come from?) and put it in the command string as a variable to run the Rhino command version.
rs.Command (“_-Snapshots Restore " + chr(34) + name_variable + chr(34) + " Enter Enter”)
You may be able to do all of this from RhinoCommon, I will see if I can figure that out, but for now, this ought to work, I think.
Hey Pascal,
Thanks a lot! I played with it for a bit longer, the " Enter" need to be " _Enter" to work.
If you figure out how to get snapshots and their other info from Rhino Common, please let me know. There are other scripts I am working on that can’t find a way of using only rs.Command. For instance, grab the layer visibility from a snapshot and over write another one.
