Now I have been around the block with this. I’ve tried functions in Python, Rhinocommon(VB.NET), and Rhinoscript and I still can’t get this to work.
I even tried a hidden “test” command called TestGetPlanarRegions.
My plan with that was simple.
Get the long lines, store them
Get the inside border line (boundary), store it
Perform TestGetPlanarRegions on each object
Run BooleanDifference, store the result.
Duplicating those as curves
Then finally deleting the surfaces and only leaving me with the curves.
But it’s just not working.
If ANYONE has any idea on how to get this going, please please let me know. This would be a LIFE and TIME saver if I could get this going.
Get sets of 2 longlines that are far apart (1+2)(3+4)(5+6) etc…
Split border by longlines
Get border segments between longlines
Perform a curve boolean with these sets and the border segments inbetween.
yea I get what you’re saying. But what I am trying to get out of this whole thing is… NOT clicking inside each “island” during CurveBoolean… I want to select the long lines, then select the border and POOF, its all good.
The only problem, is that it leaves behind any lines that were touching the border… but this is start
Dim stTeak, stBorder
Dim surTeak, surBorder
Dim boolResult
Dim surToCurve
stTeak = Rhino.GetObjects("Select the teak lines", 4, True)
If IsArray(stTeak) Then
stBorder = Rhino.GetObjects("Select the border", 4, False)
If IsArray(stBorder) Then
Rhino.UnselectAllObjects()
Rhino.SelectObjects(stTeak)
surTeak = Rhino.AddPlanarSrf(stTeak)
Rhino.DeleteObjects(stTeak)
Rhino.SelectObjects(stBorder)
surBorder = Rhino.AddPlanarSrf(stBorder)
Rhino.DeleteObjects(stBorder)
boolResult = Rhino.BooleanDifference(surBorder, surTeak)
Rhino.SelectObjects(boolResult)
Rhino.Command("_DupBorder")
Rhino.DeleteObjects(boolResult)
Else
Exit Sub
End If
Else
Exit Sub
End If
End Sub
I see you are right that here is no obvious way to have a curve boolean with open curves…
How about this:
Sort longlines in the height order.
Get border segments between longlines:
if 2 borderline segments between the longlines:
connect end to start end to strat
if 1 borderline segment between the longlines:
close segment
The teak planks need to be the width of the actual plank… not the width of inbetween them… if that makes any sense lol.
Call Main()
Sub Main()
Dim stCrvA, stCrvB
Dim result
Dim obj, objB, objC, objD
stCrvA = Rhino.GetObjects("Select Teak", 0, True)
stCrvB = Rhino.GetObjects("Select Border", 0)
Rhino.Print("Working teak lines....")
For Each obj In stCrvA
For Each objB In stCrvB
Rhino.CurveBooleanIntersection obj, objB
Next
Next
Rhino.Print("Cleaning up loose objects.....")
For Each objC In stCrvB
Rhino.DeleteOBject(objC)
Next
Rhino.DeleteObjects(stCrvA)
Rhino.Print("COMPLETE!")
End Sub
Now…
It’s pretty slow with lots of objects.
Also… according to the docs, Rhino.CurveBooleanIntersection is supposed to return the object that was created. Hence why I have a varible named result.
I was going to have it setup like so
result = Rhino.CurveBooleanIntersection obj, objB
Rhino.ObjectLayer result "Layername"
But result is always null.
I wanted to put all the objects that it returned on a certain layer, but anything that it returned was null for some reason.
Maybe @clement can shed some light on why this is.
I tried to mess with arrays and add each result to an array… but old school arrays confuse the hell out of me lol.
for slight speedup, you might change this snippet:
Next
to this, non loop version:
Rhino.DeleteObjects stCrvB
And to put results on layer i guess you forgot some brackets and a comma in this snippet:
the correction would be:
result = Rhino.CurveBooleanIntersection(obj, objB)
If Not IsNull(result) Then Rhino.ObjectLayer result, "Layername"
For more speedups, you might change the redraw behaviour using Rhino.EnableRedraw(False) at the start of your script and turn it on again with Rhino.EnableRedraw(True) when the script finished or when an error occured. Note that the latter is required in case of errors, otherwise you’ll have to hold ESC to get the redraw back…
