Hi, i’m writing a plugin to send data to server from Grasshopper.
I’d like to pop up a message box upon sending, which is done using:
Rhino.UI.Dialogs.ShowMessageBox
Is there a way to trigger close this message box from my code? I will check when data is sent and would like to automatically close the message box created.
Not sure if Rhino.UI
has a similar class but in Eto.Forms
you can instantiate a Form
and make your own pop-up. Here I show you a pattern you may use
import Eto.Forms as forms
import Eto.Drawing as drawing
import time
dialog = forms.Form()
dialog.Size = drawing.Size(400,400)
layout = forms.DynamicLayout()
layout.AddSeparateRow(forms.Label(Text='waiting for 3 secs'))
dialog.Content = layout
if x:
dialog.Show()
time.sleep(3)
dialog.Close()
I put this in a GhPython component so you can feed a button into an x input
thank you for the eto form suggestion! will try
