Audible cue on errors?
Is there any way have a little “chirp” when a command failed?
I’m using hotkeys for different tools and most often than not I don’t need to pay attention to the command line.
Sometimes command fail without visual cue (for example attempting split at a single point a closed curve while it so zoomed in, and you don’t know it’s closed curve)
An audio cue when something went wrong could help efficiency.
Thank you.
For now, this script seems to work ok, although some commands return “Nothing” for both failure and if nothing changed, this script doesn’t deferential and plays sound for both.
-RunPythonScript "CommandFailSound.py"
launch once to activate event listener, launch again to disable it
CommandFailSound.py
import Rhino
import scriptcontext as sc
VERSION = "26.03.31.174234"
_WATCHER_KEY = "rhino.command_fail_sound.watcher"
_APP_EVENT_NAMES = ("CommandEnded", "EndCommand", "CommandFinished")
_COMMAND_EVENT_NAMES = ("EndCommand", "CommandEnded")
_RESULT_ATTRS = ("CommandResult", "Result", "RunResult")
try:
    _SUCCESS_RESULT_INT = int(Rhino.Commands.Result.Success)
    _CANCEL_RESULT_INT = int(Rhino.Commands.Result.Cancel)
except Exception:
    _SUCCESS_RESULT_INT = None
    _CANCEL_RESULT_INT = None
def _write(msg):
    try:
        Rhino.RhinoApp.WriteLine("[CommandFailSound {0}] {1}".format(VERSION, msg))
    except Exception:
        pass
def _event_candidates():
    app = getattr(Rhino, "RhinoApp", None)
    if app is not None:
        for name in _APP_EVENT_NAMES:
            yield app, name
    command_type = getattr(getattr(Rhino, "Commands", None), "Command", None)
    if command_type is not None:
        for name in _COMMAND_EVENT_NAMES:
            yield command_type, name
def _normalize_hook(hook):
    if isinstance(hook, tuple) and len(hook) == 3:
        return hook
    if hook:
        return (Rhino.RhinoApp, "CommandEnded", hook)
    return None
def _detach_handler(source, event_name, handler):
    try:
        if hasattr(source, event_name):
            event_obj = getattr(source, event_name)
            event_obj -= handler
    except Exception:
        pass
def _detach_current_handler_everywhere():
    for source, event_name in _event_candidates():
        _detach_handler(source, event_name, _on_command_ended)
def _play_sound():
    try:
        import sys
        if sys.platform == "darwin":
            try:
                import subprocess
                subprocess.Popen(
                    ["afplay", "/System/Library/Sounds/Pop.aiff"],
                    stdout=subprocess.DEVNULL,
                    stderr=subprocess.DEVNULL,
                return
            except Exception:
                pass
            try:
                import subprocess
                subprocess.Popen(
                    ["osascript", "-e", "beep"],
                return
            except Exception:
                pass
    except Exception:
        pass
    try:
        import winsound
        winsound.MessageBeep(winsound.MB_ICONEXCLAMATION)
        return
    except Exception:
        pass
    try:
        import System
        System.Media.SystemSounds.Exclamation.Play()
        return
    except Exception:
        pass
    try:
        import System
        System.Console.Beep(1200, 120)
    except Exception:
        pass
def _event_result(event_args):
    for name in _RESULT_ATTRS:
        value = getattr(event_args, name, None)
        if value is None:
            continue
        if callable(value):
            try:
                value = value()
            except Exception:
                continue
        return value
    return None
def _is_failure(result):
    if result is None:
        return False
    try:
        value = int(result)
        if _SUCCESS_RESULT_INT is not None and value == _SUCCESS_RESULT_INT:
            return False
        if _CANCEL_RESULT_INT is not None and value == _CANCEL_RESULT_INT:
            return False
        return True
    except Exception:
        text = str(result).lower()
        if "success" in text:
            return False
        if "cancel" in text:
            return False
        return ("fail" in text) or ("nothing" in text)
def _on_command_ended(sender, event_args):
    try:
        result = _event_result(event_args)
        if _is_failure(result):
            _play_sound()
    except Exception:
        # Never let event handlers throw into Rhino event loop.
        pass
def _install():
    if _normalize_hook(sc.sticky.get(_WATCHER_KEY)):
        _write("Command-fail sound watcher is already enabled.")
        return True
        if not hasattr(source, event_name):
            continue
        try:
            event_obj += _on_command_ended
            sc.sticky[_WATCHER_KEY] = (source, event_name, _on_command_ended)
            _write(
                "Command-fail sound watcher enabled via {0}.{1}.".format(
                    getattr(source, "__name__", source.__class__.__name__), event_name
            return True
        except Exception:
            continue
    _write("No supported command-end event was found in this Rhino build.")
    return False
def _remove():
    hook = _normalize_hook(sc.sticky.get(_WATCHER_KEY))
    if not hook:
        _write("Command-fail sound watcher is not enabled.")
        return False
    source, event_name, handler = hook
    sc.sticky.pop(_WATCHER_KEY, None)
    _write("Command-fail sound watcher disabled.")
    return True
def ToggleCommandFailSound():
        _remove()
    else:
        _install()
if __name__ == "__main__":
CommandFailSound.py (5.5 KB)
