Attribute user text
I have just learned that you can script user text in Rhino. I want to ask, if it has to look like this or if I am doing something wrong?
Are there any plans for this to get a proper UI? For start, the text window should have a small icon that would switch between anchored and big floating window. Changing the referenced object is also cumbersome, I guess some color-coding could help? I mean, I could use GH but there exists this function in Rhino so I wanted to give it a try.
Hi kral -
You are not doing anything wrong.
No.
The complaint has been on the list for a while: RH-55283 Working with text field syntax is awkward
