Atrocious panning with floating viewport opened in the background
Hello.
With an object selected in a complex drawing with floating viewport opened and any other viewport is focused, panning with middle mouse is extremely laggy.
Taskmanager reports only 8% CPU usage, 0% GPU usage in safe mode and 1% CPU, 10%GPU in normal, panning in focused floating viewport brings GPU usage to 15%
Same issue in Rhino 9 BETA, 9.0.26293.12303
System Info
Rhino 8 SR37 2026-10-21 (Rhino 8, 8.37.26294.11001, Git hash:master @ a6592128d921cf5111f81ead500d1035845fda34)
License type: Commercial, build 2026-10-21
License details: Cloud Zoo
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 16GB)
.NET 10.0.8
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 9-30-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 617.42
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 9-30-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 617.42
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2026
Driver Version: 32.0.16.1742
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
D:\github\rhino\vFileTypeTemplate\bin\Release\Rhino8\net7.0-windows\vFileTypeTemplate.dll “vFileTypeTemplate” 26.8.25.1813
D:\github\rhino\vAutoBackup\bin\Release\Rhino8\net7.0-windows\vAutoBackup.dll “vAutoBackup” 26.7.23.1911
D:\github\rhino\vAltGrShortcutFilter\bin\Release\Rhino8\net7.0-windows\vAltGrShortcutFilter.Rhino8.dll “vAltGr Shortcut Filter” 26.10.28.2031
D:\github\rhino\vObjectPropertiesPlus\bin\Release\Rhino8\net7.0-windows\vObjectPropertiesPlus.dll “vObjectProperties+” 26.11.2.1223
D:\github\rhino\vTools\bin\Release\Rhino8\net7.0-windows\vTools.dll “vTools” 26.11.2.1329
D:\github\rhino\vArtful\bin\Release\Rhino8\net7.0-windows\vArtful.dll “vArtful” 26.9.28.1611
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.37.26294.11001
Hi Vano,
i wasn’t able to repeat this here with a floating viewport open and a group selected, panning stays smooth in the main view. Can you post the file from the video? Also, does the lag go away if you deselect everything, or if you just turn the gumball off with the selection still active? Thanks!
We should also try running in SafeMode to see if something here is affecting things.
The video was made in safe mode. Also, in the video shown that there is no lag in main view when nothing is selected, or when panning inside floating viewport with or without selection.
It seems it updates the view only after mouse stopped for a moment.
Turning off gumball actually fixes the issue.
panning_float_viewport.3dm (2.2 MB)
Not able to repeat, but i’m on a newer version. Do you have a Rhino 9 license? Its now either 90 evaluation of Rhino 9 or requires a license.
