I don´t use this command too much (arrowhead on curve), but does it work on mac? I can´t make it work!
Using Version 6 (6.23.20035.13182, 2020-02-04)
yeh works ok here on Rhino6 Mac & WIP Mac
weird, WIP works fine here as well, R6 not.
Works for me too in latest version of Rhino 6!
Hello - what happens? Does the command start then do nothing when you click on a curve, or?
Hi @pascal Pascal,
basically, yes. Command starts, but after clicking the curve, the arrow does not appear. Or is there any setting in R6 controlling the scale …?
Petr
Hi @petumatr, are you still experiencing this issue? I have had this issue for about a month or two now.
Hi @pascal — I can subtly see a graphical dot almost microscopic that appears after running the command. That allows me to assume that the command has been run and it has effected the selected end of the line, but it is not representing itself properly.
I am using Rhino for Mac Version 6 (6.24.20079.23332, 2020-03-19)
Added info below:
Rhino 6 SR24 2020-3-19 (Public Build, 6.24.20079.23332, Git hash:master @ 064283610b834170e52117f2656605b5b25d65c0)
License type: Educational, build 2020-03-19
License details: Cloud Zoo. In use by: Shane Jezowski ()
Apple Intel 64-bit macOS Version 10.15.4 (Build 19E266) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro15,3
Machine name: Shane’s MacBook Pro
Language: en-US (MacOS default)
AMD Radeon Pro Vega 20 OpenGL Engine (OpenGL ver:4.1 ATI-3.8.24)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: Radeon Pro Vega 20
Displays: Color LCD (258dpi 2x), LED Cinema Display (94dpi 1x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
Radeon Pro Vega 20 (4 GB)
Color LCD (1680 x 1050)
LED Cinema Display (1920 x 1200)
USB devices
Apple Inc.: USB3.1 Hub
Western Digital : External HDD
Apple Inc.: Apple LED Cinema Display
Apple Inc.: Display iSight
Apple Inc.: Display Audio
Apple Inc: USB-C Digital AV Multiport Adapter
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
Broadcom: Magic Keyboard with Numeric Keypad
Broadcom: Magic Mouse 2
Third party kernel extensions
com.Apowersoft.driver.AudioDevice (1.6.7) EDEB490C-96A8-34E2-BC40-D74C2AACEFF2
com.Cycling74.driver.Soundflower (2) 2D779840-7439-31E5-8A66-D786C3F47B75
com.google.drivefs.filesystems.dfsfuse (37.0.8) C2A01415-1D42-346C-8B38-5216B79DEF81
com.box.filesystems.osxfuse (303.10.2) 737D416E-72BC-33A0-9DC8-8F66F3567164
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/Users/shanejezowski/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.rhp/libDLRhinoNative.dylib
/Users/shanejezowski/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.rhp/libPolygonCruncherSDK.dylib
/Users/shanejezowski/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.rhp/libSyncData.dylib
/Users/shanejezowski/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.rhp/libomp.dylib
/Users/shanejezowski/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.rhp/libc++.1.dylib
Rhino plugins
/Users/shanejezowski/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Panelingtools.rhp “PanelingTools” 6.24.20079.1002
/Applications/Rhinoceros V6.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 6.24.20079.1002
/Applications/Rhinoceros V6.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.24.20079.23332
/Applications/Rhinoceros V6.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.24.20079.23332
/Applications/Rhinoceros V6.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.24.20079.23332
/Users/shanejezowski/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Iris.MacR5.rhp “Iris” 1.0.0.0
/Users/shanejezowski/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.0.0
/Applications/Rhinoceros V6.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.24.20079.1002
/Applications/Rhinoceros V6.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.24.20079.1002
/Applications/Rhinoceros V6.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.24.20079.23332
/Applications/Rhinoceros V6.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.24.20079.23332
/Applications/Rhinoceros V6.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.24.20079.1002
/Applications/Rhinoceros V6.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.24.20079.1002
