Arraying circles with varying radii along a curve
Hello!
I am trying to array circles with 3 different radii randomly along a curve but I haven’t been having any luck.
I started by trying with the divide distance as that would allow me to set a base diameter for each circle but the divide distance applies the different distances simultaniously, so it ends up dividing the curve multiple times.
Here is a picture of what I am trying to achieve (sorry for the bad drawing)
The circles should be tangent to eachother.
I have tried that solution but it doesn’t seem to be working, as I am not trying to move the circles manually. I want to divide a line with the distances of the diameter and then divide those diametres into the circle radii.
I have found another workaround, that does not guarantee the tangency of the circles but seem close enough for me at least:
This is the result of what I did:
Why not posting your script with the curve internalized ?
I am sure someone will provide you a working script.
I did that by code
disanceOnCurves_LEGACY.gh (9.4 KB)
  private void RunScript(Curve curve, List<double> radiuses, ref object A)
    //Calculate the center of circles with specified radius on a curve
    List<Point3d> lst_points = new List<Point3d>();
    Point3d pointOnCurve = CurveCircleIntersection(curve, curve.PointAtStart, radiuses[0]);
    lst_points.Add(pointOnCurve);
    for (int i = 1; i < radiuses.Count; i++)
      double radius = (radiuses[i - 1] + radiuses[i] );
      Point3d pointOnCurveNew = CurveCircleIntersection(curve, pointOnCurve, radius);
      if (pointOnCurveNew != Point3d.Unset)
        pointOnCurve = pointOnCurveNew;
      else
        break;
    A = lst_points;
  // <Custom additional code>
  /// <summary>
  /// Calculate the point on a curve that is at a certain radius from a point
  /// this point must be after the previous point
  /// </summary>
  /// <param name="curve">The curve</param>
  /// <param name="point">The point on the curve</param>
  /// <param name="radius">The radius at which the new pointt must be from previous point</param>
  /// <returns>Next point, Point3d.Unset if no point found</returns>
  Point3d CurveCircleIntersection(Curve curve, Point3d point, double radius)
    double tolerance = 0.0001;
    double overlapTolerance = 0.0001;
    Point3d output = Point3d.Unset;
    double t = double.NaN;
    curve.ClosestPoint(point, out t);
    if (t != double.NaN)
      Circle circle = new Circle(Plane.WorldXY, point, radius);
      CurveIntersections ci = Rhino.Geometry.Intersect.Intersection.CurveCurve(curve, new ArcCurve(circle), tolerance, overlapTolerance);
      double tMinOK = double.NaN;
      foreach (IntersectionEvent ie in ci)
        if (ie.ParameterA > t)
          //First parameter that is OK
          if (Double.IsNaN(tMinOK))
            tMinOK = ie.ParameterA;
            output = ie.PointA;
          else
            //If a parameter is nearer
            if (ie.ParameterA < tMinOK)
              output = ie.PointA;
    return output;
Look at plugins for Jewels, Peacock, …
See these threads
If you want aligned circles on the curve like this , they must intersected
The script @laurent_delrieu posted above does work without intersections - the circle centers lie on the curve, not the points of contact between the circles.
Yes, i said “like this” as shown in the picture
Sorry - didn’t mean to suggest you’d not understood, just highlighting the difference for other readers.
Do not be sorry, i understand you and the original question should be clearer
Using a mesh with an image to calculate a radius with a brightness, so all circles are tangents and here are on a spiral
SCARLETT JOHANSSON BY LEETA HARDING
Joconde
With Hilbert Curve
Andy Warhol’s Marilyn Monroe
I said sorry for the bad drawing and stated I wanted the circles tangent to eachother.
How clearer should I be?
Thank you! your replies have been very helpful!
I will take a look at these topics.
Questions will not be clearer with “sorry”
If you don’t accept the solution of @laurent_delrieu , what you want?
I said sorry and clarified what I wanted.
What more do you want then?
Can you be clearer on how should I be clearer in my question?
I havent accepted the solution yet because I haven’t had the chance to test the solutions out.
Once I find a suiting solution I will mark this as solved.
If you don’t want to help you can refrain from replying. I didn’t ask you personally for a solution, you don’t need to act offended when someone doesn’t think your solution works for their needs.
I think this would be a great solution.
Do you know what script was used for this?
I think it was not your question. So the question for this thread seems to be answered on discussion n°4.
For image technique see this thread
Thank you!
