I have a drawing like this. I want to array this blue curve. But when I use array curve command, blue line doesnt follow 2 red lines. How can I make this the way I want?
Dear @Aiden_Pearce
you can build a
(1) _loft
or maybe a _sweep2
between the 2 red curves (or with the 2 red curves as rails)
then
(2) _divide
the lower curve with the amount of curves you need.
(3) “_extractIsoCurve” to get the curves you’re searching.
if this does not help, please post a .3dm file and sketch the desired result on above screenshot. kind regards -tom
Thanks a lot!
