In Rhino I have 50 groups of geometry that I baked out of Grasshopper.
The groups of geometry have been baked using Elefront so that each group is in a serparate layer, only when they got backed, they all ended stacked up on each other (i.e. they were all backed to the orgin)
So to separate them all so they’re not stacked is to select each layer and move it 20 units in the x direction, then the next layer 40 units, then the second 60 units etc
I am wondering if anyone knows of any scripts, commands or grasshopper plugins that would be able to arrange all of the different groups into a grid by layer…
Can you post you example .3dm file and any attempt you have made at a gh script? Best way to get someone to help is to provide a bit of work to work from.
