Area textfield of copied group
For example:
I have a group with a closed curve and a text field in it, which shows me the area of the object. As soon as I copy the group and scale the duplicated closed curve, the area doesn´t change, because the textfield is connected to the first object. The problem is, that I always have to reconnect the new textfields with the new objects.
Is there any possibility, that textfields in groups always refer to the closed curve in the same group?
Thank you in advance.
Hi Kemal -
When you have created a copy of the group and modified the curve, run the TestMatchAnnotationFields command. As prompted, pick the annotation in the new group, then the curve in the new group. Run Lock and select the old annotation. Hit the Delete button and Unlock.
Hi Wim, thank you for your quick reply! Your method is making it easier. Nevertheless, a real-time update of the annotations would be great.
