How can you find the direction an arc is drawn. If you run this script and select either of the 2 arcs in the attached file you get the same answer.
Option Explicit
'Script written by <insert name>
'Script copyrighted by <insert company name>
'Script version 17 June 2015 16:17:28
Call Main()
Sub Main()
Dim strObject, dblAngle, arrPointStart, arrPointEnd
strObject = Rhino.GetObject("Select arc")
If Rhino.IsArc(strObject) Then
dblAngle = Rhino.ArcAngle(strObject)
arrPointStart = Rhino.CurveStartPoint(strObject)
arrPointEnd = Rhino.CurveEndPoint(strObject)
Rhino.Print "Arc angle: " & CStr(dblAngle) & " Arc Start: " & Rhino.Pt2Str(arrPointStart) & " Arc End: " & Rhino.Pt2Str(arrPointEnd)
End If
End Sub
I’d like the 180° as positive or negative, is there some way to find this.
Also seems odd that the answers from the script ignore the direction the arcs are drawn.
Thanks Mark.
temp.3dm (32.9 KB)
