The direction of an arc curve is counter-clockwise in relation to the plane on which it lies. The starting point of an arc curve alway lies on the arc plane’s x-axis.
If the curve may have been flipped, then you can get the center point of the Arc, and then calculate the Plane Normal (or CrossProduct) based on the the StartPt and EndPt (and Center) of the Arc. The direction of the Normal will then imply the direction of the Arc.
If you already know the Plane and no flipping of the curve has happened, then you know the direction of the Arc (CCW).
If you prefer going to the other side of the river to get some water then compare the angles between StartPt and EndPt of the arc relative to the Arc Center. The angles:
