Hi everyone!
I am using elefront plugin for creating dimensions because with that component I am able to select which dimension style I want to use and that feature is preaty cool. But I can use that feature just for straight lines because there is no something like define arc curve.. As you see I am using Arc dimension command actually It shows the angle but I am rewriting the lenghts on it. That way is not so good.
Is there a way to make dimensions for arcs but with dimension styles?
