Arc - BothSides?
_Arc - BothSides
i could of used that a few times lately.
so just making a low level suggestion and/or seeing if anybody else would have uses for it.
(pick center point then the start point is actually the midpoint of the arc)
Hi Jeff
Try the below Python script:
# Python script Arc_BothSides
# Write by Ing. Vittorio Carlotto
# carlottovittorio@gmail.comn
def  Arc_BothSides():
        arrplane=rs.ViewCPlane()
        rs.Command("_Arc")
        result=rs.LastCommandResult()
        if result==0:
            arc_id=rs.FirstObject()
            pc=rs.ArcCenterPoint(arc_id)
            ps=rs.CurveStartPoint(arc_id)
            pe=rs.CurveEndPoint(arc_id)
            angle=rs.ArcAngle(arc_id)
            matrot=rs.XformRotation2(angle,arrplane.ZAxis,pc)
            pb=rs.PointTransform(ps,matrot)
            result_2=rs.PointCompare(pe,pb)
            if result_2==True:
                matrot=rs.XformRotation2(angle,-arrplane.ZAxis,pc)
            rs.AddArc3Pt(pe,pb,ps)
            rs.DeleteObject(arc_id)
        else:
            return
Arc_BothSides()```
Ciao Vittorio
Dang, Vittorio, you beat me to it…
However, I decided to use this as my first entry in the club of dynamic drawing scripts. It’s actually inspired from one of your scripts Vittorio !!  (the half circle) You set a center point and a midpoint (you can enter a value to constrain the midpoint to a radius as usual), then drag the arc to where you want it. You can alternatively type in an angle value and enter. I used the total included angle, not the half angle - don’t know what’s more convenient, but it’s easy to change.
So, here it is, I haven’t tested it extensively, and not at all on Mac, so @jeff_hammond let me know if it works for you…
–Mitch
(updated again… better initial plane control)
ArcFromMidpoint.py (2.7 KB)
Hi Mitch
Thanks for your version.
There is an error at line 69:
I modified :
sPt=rs.PointTransform(gp.Point(),xFormR)
with
sPt=rs.PointTransform(mp,xFormR)
Ciao Vittorio
nice fellas.
I’m drawing a little later today. I’ll try it out then. thanks
Hi Vittorio,
Yeah, dumb error, sorry… Thanks for checking! I updated the original script…
Cheers, --Mitch
Hi Mitch
The attached script is a modifycation of your script
Ciao Vittorio
ArcFromStartPoint_BothSides.py (2.5 KB)
Ah, interesting variation, thanks Vittorio!
@jeff_hammond I updated the script again with some minor improvements… and it runs on Mac!
–Mitch
finally got a chance to try it and it’s great. (the one from the 3rd post in this thread at the time of me posting this).
also, i really like the live feedback/dynamic aspects.
thanks a ton @vittorio @Helvetosaur !
this one is definitely getting an alias :wink:
i imagine both would have uses but i think you’ve written it the dominant way… the things i currently want to do with it are via inferencing but who knows, i might be bumping the topic in a few months asking how to switch it to 1/2 angle.
