Applying voronoi to a sweep model, data error occoured can you help?
hi ı have been trying to cover 3d model with voronoi. ı made the 3dmodel with sweep command. the polyline command on the grasshopper give the error “insufficient points for a polyline”. I do not understand what points should ı add. ı think ı did not add enough data for the sweep. what should ı do you think?
sweepvoronoi.gh (18.9 KB)
It’s working fine here - maybe try rerunning in a new file or adjusting your tolerances to be more accurate? Imo Discontinuity is not super useful for curves and I would reconsider how you’re rebuilding your intersections as polylines - using divide curve or maybe turning your Sweep surface into a mesh before the intersection spring to mind
-Sash
