Applying pattern to surface
This is my first time using Grasshopper, I used this video https://www.youtube.com/watch?v=VUHD8AkHtcg&ab_channel=JuneLee but theres no explanation on how to apply it to a surface, could someone help?
perforated surface.gh (13.4 KB)
Perforated surface model.3dm (2.4 MB)
welcome to the forum :slight_smile:
please do not create multiple thread regarding the same topic, there’s a tiny button on bottom right that should allow you to edit a message you posted earlier:
you can also use the trash button to entirely delete a comment / thread:
in your case to connect a custom surface instead of the one you have generated, it could be enough to just replace the rectangular surface with a Surface container (Parameter) and link that to your surface in Rhino:
Thank you! Sorry I created two threads, I wanted to add the file but couldn’t edit the post because it was on revision.
Also, if i want to delete the circles I created in grasshopper, so I can have a perforated facade, how would I do that?
Users posting for the first time don’t have permission to edit topic names.
@inno sorry for being nosy, may I ask what screen-recorder you’re using to capture keystrokes and not just mouse clicks? I use a few different ones, some paid (swordsoft, pointerfocus, autodesk screencast ← discontinued) and some free or opensource (OBS, carnac). I use SnagIt for must screen-recording but I wish it also captured keystrokes, usually I have to use it along with one of the aforementioned apps.
I’m using Autohotkey to display key press and mouse clicks
this one: Release Captura v8.0.0 · MathewSachin/Captura · GitHub
mouse clicks and keystrokes highlight is here:
