Hello Community,
Is there any way to select/fill the closed triangles areas that appear between lines. I do not know any possible solution.
Best is to share a file. What does the fill need to be? A surface? A mesh? A hatch?
A hatch would be wonderful. A surface probably?
I can not share a file. Can you just suggest so steps.
It’s hard to make suggestions without. The method depends on how your geometry is created.
Its basically rectangles with a filets and the space in the filets needs to be filled. However not all rectangles are complete, some end abruptly.
I’d say, extract all arcs, see if they are .5pi radians, check if they share an endpoint, if the do, join them, close the curve and fill.
Try curve Boolean !
