Fill the gap between closed lines/Curves using surface
It might be a silly question.I’m trying to fill the gap between closed lines/curves with surface. So i started creating a plane surface over it and trimmed it but one side i got the result what i need to achieve but for the other side I’m facing the problem while trimming it i don’t know why it’s happening. Is there any solution to it.
I attached the rhino file too.surface in gap.3dm (74.4 KB)
Thanks in advance.
There are two curves that are not closed among your 5 curves.
Boundary Surfaces_re.gh (13.2 KB)
Thank you so much @HS_Kim :heart: for helping me in solving this.
