Is there a possibility to change the units of annotations?
For example, I have an a project in millimeters, but want an annotation to display in meters (and also would be nice, to have precision of 0.01, different from project precision of 1).
Hi @Kida yes, this is possible already if you edit the Grasshopper definition that generates this annotation. I’ve developed it a bit further and included a new parameter to control that. Find below the updated version of the Elevation mark.
Hi @Kida In order to add more parameters to the Annotation style created from a Grasshopper Style you need to edit the original Grasshopper definition. The “Annotation” object components in Grasshopper can be used to reference annotation objects, or create new ones. I share the Grasshopper script used for this Elevation mark that includes the unit converter, just in case you need to modify it.
