My model is set to Imperial (feet and inches), but the elevation marker is in meters. Is there a way to change this?
Hi Shane,
The “Elevation Mark” annotation style is a “Grasshopper style” (style that uses a GH definition) that was not designed to be used in Imperial units. Use this new style attached instead. (Run the vaStylesImport command to import it)
Elevation Mark Imperial.val (47.5 KB)
