Hi, i have noticed the annotation bug. When trying to place annotation (f.e. wind rose) the text is scaled 1000 times in spite of the toolbar is showing correct text height.
Hi @petumatr, we are aware of this error. I’ll let you know when we fix it.
Thanks!
hmmm, anyway I have found a workaround…I am able to edit the style and change units from meters to milimeters…but yes, it would be nice to have these styles according to the current template…
Thanks!
@petumatr This error with the scale of Annotation texts has been fixed in VisualARQ 2.3, which is already available for download: VisualARQ 2 - Version 2.3 released
Hi Francesc,
I have downloaded the 2.5.1. and I am still having the same problem with annotations in mm template style.
Cheers, Petr
Hi @petumatr,
You are right, it still doesn’t work. Sorry for the inconvenience, we will let you know once this is fixed.
Kind regards
Hi Petr, try this out with VisualARQ 2.6. It should work well now. https://www.visualarq.com/2019/11/04/visualarq-2-6-available/
Hi and thanks, I will try it out!
Petr
