Not sure it qualifies as a Gallery entry per se, but these are some videos that are generated as part of the UnitTest project in Grasshopper 2.0
Testing correctness of oriented ellipse implicit equations:
Iterative median filter with an overlaid numbermap which controls the window circle radius:
Testing the difference between square and circular median windows:
Growing the size of the median window over time:
Two more, showing a per-pixel radius effect and a warp transform.
Hi david.
How did you record it ? … only camtasia (alternative … ) or you rendered it ? Its very nice.
Peter
DavidRutten
(David Rutten)
November 7, 2016, 10:44am
#4
They’re rendered to individual bitmaps, then composed using VirtualDub. Unfortunately these aren’t quite real-time, anywhere from 0.25 to 1 second per frame to generate and save it to disk.
