Animate Rendering in GH
Not sure there is an easy solution for this…
Searched for it but didn’t find any obvious solutions.
I want to animate and render 3 sliders in GH at once to generate multiple combinations (or continuous series) of these.
Kind of like the gene pool which you cannot animate as a slider (if i wanted random samples). But Sliders only work one at a time if you want to animate them. I also have not found how to stop them once they are working… Other than using a slider connected to nothing which will stop the current animation running…
I guess I could generate a matrix of combos from these sliders to reference as a list a slider could point to (it’s gonna be a huge file) and animate that slider index (which i can’t feed min to max values in the animation interval automatically). Or use the repeat module (but again it only takes one feed - not x sliders)?
What’s the obvious GH native solution?
A script… I got it but I am in a period where I don’t want to script…
Lots of values to travel. I want to animate 3200 images for example…
this will give you every combination of N = 3 lists
here you have 20 x 20 x 80 = 32000 possible combinations, which you wire into an Item
component
you only animate the slider on the bottom. the sliders are replaced by ranges in my example
combination.gh (14.6 KB)
Plus I learned you could add more inputs to the holistic module! Thanks! :slight_smile:
Added side effect, if you modify the GH definition mid-animation, it will adapt! WOW!
