@AndyPayne Amazing! But I have another problem with Kangaroo’s angle constraint, please check it out.
As you can see there’s a polyline, I want the angle between each pair of segment to be the same angle. It works when the curve is short, but when it gets longer, the angle constraint begins to lose its power, and the longest line doesn’t even move. This shouldn’t have happened.
This flaw confused me for few days, because all other constraints works in large scale model, except this. So could you please fix this, since it’s impossible to scale my project model to a microscopic size each time to use Kangaroo.
@tomjerry1087 I’m not sure I understand why you’re question was posted in this thread? These widgets don’t have anything to do with Kangaroo. Perhaps @DanielPiker will need to weigh in.
Also, I recommend always using the regular (non-bouncy) solver if in doubt, as this is the one designed for fast convergence. The bouncy version is mainly just for animations.
With these changes both scales converge near instantly:
However, I don’t think your question has anything to do with this thread it is posted in though, so if you have more questions on this please post them in a new thread.
Alright. Indeed it’s not a proper place to post this, but this issue just occured and I failed to find a Kangaroo topic, so I post it here to see if this can be solved in future updates. And thanks for noticing it ;D
