Anexact Aescapes V2.0 will explore the advanced digital modeling techniques to generate complex architectural compositions with Rhinoceros. ‘Anexact’ architectural objects resist being reduced to pure geometric forms. Being ambiguous, irreducible, and rigorous, these objects embrace the immense qualities that exist in any form. The multiple techniques and operations can be leveraged in the conceptual stage of any project. The explorations will wrap several frames, and we will be diving deeper into the notion of how newer properties appear when autonomous architectural masses interact with each other. Participants will learn to develop models that speculate on various qualities of articulations and the interaction of masses. Rather than using a sketch as an end goal, we use it as a starting point and then taking it forward while developing a 3D composition, seeing how far we can go with it using a series of simple compounded operations in Rhinoceros. The webinar will demonstrate how to take full advantage of manual modeling in Rhinoceros and SubD to create complex geometries you might not believe could be manually designed without parametric tools.
Posted Mar 03, 2022 by Carla Sologuren on Rhino News, etc.
