Rhino for Architecture workshop Vienna, Austria June 15-16, 2015
The workshop will showcase the different uses of Rhino along the process of architectural production, from conceptual development through construction documentation. Starting with an overview of Rhino as an all‐around tool for conceptualizing and developing architectural models, the class will then illustrate the potential of the software for geometry control, rationalization and the coordination of information across the design team. Further options for documentation production, visualization, interoperability with other software and BIM compliant workflows will be demonstrated. Each subject will be explained through the step‐by step development of examples and built case studies with detailed analysis of key commands and critical workflows.
Vincent Nowak (FlowArchitecture) and Annarita Papeschi (ZahaHadidArchitects) will share their detailed knowledge from their direct experience working on large complex projects at Zaha Hadid Architects as well as the intracacies of integration on smaller projects as Flow Architecture. Together they will demonstrate, through actual Case Studies, how Rhinoceros was used in the design of various building parts and then ultimately integrated with other software packages to smoothly move between design and construction in a rational and efficient manner.
Complete details and registration…
Posted May 12, 2015 by Carlos Perez on Rhino News, etc.
