In a particular file, I used Purge to purge all the unused hatch patterns - there are two still being used that are not among the ‘default’ ones. Here is the list from DocumentProperties>Hatch visually:
(the two non-default ones are listed just after ‘Solid’)
Now, here is the list in the Properties panel:
Clearly the hatches which have been purged from the file are still showing up in the list. Looks like bad programming.
Back to DocumentProperties>Hatch:
- Why is it not possible to purge the ‘default’ hatch patterns from the file even though they are not used?
- Why is it not possible to rename a non-default hatch pattern? (Rename is grayed out)
