I have a panel that already has a perforation pattern. I want to optimise the percentage of the opening areas and therefore I want to be able to take the existing pattern and modify it. Is this possible?
Thank you for your help in advance!
Sorry I’m still learning GH
I have attached an image of the surface in question.
I uploaded the rhino file of the panel. The pattern is an existing one and I want to use this as baseline and then modify it so I can see the effect of different percentages of openings. This is part of a shadow analysis. The pattern layout is not fixed so it can be random, I am more interested in the different opening areas if that makes sense.
I have a DWG that has the pattern, so if I understood you correctly, do you suggest to take the pattern as curves into GH and then apply that to a surface?
