Hi, I used the split tree component to get an alternate grid structure, and further to use this grid for a zig-zag polyline. But the split tree component is showing weird results.
Gh definition is attached below: zigzag.gh (6.1 KB) “Desired result”
I hope to get some help with this. Thanks!!
like this?
zigzag_re.gh (8.4 KB)
Yes!! Thanks, would mind explaining me where was it getting wrong?
Check this as well.
Well u didnt think about how to “weave” two branches together to get the desired result I don’t think split tree can do that.
But I guess there is a more eglegant way with Relative Item component, but I’m not familiar with it.
Edit: thanks @HS_Kim for the more elegant solution
Thanks bud!
I tried this with cull pattern logic , it gives me same result as yours. But i was intrested in doing with splittree. Thanks for your help.
