Allow auto login via password / tokens for Yak push
I’m trying to set up a GitHub action for auto building and pushing my GH plugin.
The current problem of making everything automated is the login process.
By default, if I do it on my own computer, the yak login will open a webpage and I need to click it to log into my account.
However, this process is not feasible for Github Actions…
Is there a way to pass this step with some login token?
yak login --ci
will give you a token you can use
Thanks! super fast reply.
for
https://accounts.rhino3d.com/oauth2/auth?response_type=id_token+token&client_id=yak&redirect_uri=http://localhost:5123/&scope=profile+openid+email+noexpire&state=<token>`
You mean the token is the token part?
How do I use it for yak login then?
When running yak login --ci the browser still opens.
Yes, It’ll put a token into your command line you can copy and paste into your github secrets, then use that as an environment variable.
~\gits
❯ & $yak login --ci
Your browser has been opened to visit:
https://accounts.rhino3d.com/oauth2/auth?response_type=id_token+token&client_id=yak&redirect_uri=http://localhost:5123/&scope=profile+openid+email+noexpire&state=<redacted>
Your non-expiring(+) token is shown below. Use this to set the YAK_TOKEN
environment variable on your build machine. Remember to keep it safe!
<REDACTED>
+ OK, actually this token expires in 49 years (2075-03-20T16:30:19.8313115+01:00)
Wait, then how do you use that YAK_TOKEN variable?
Am I suppose to use any mcneel provided action files, OR, how should I use that token with yak command? Will it find a Environmental variable automatically?
In your Github Action you can provide the api token (YAK_TOKEN) as an environment variable and then you don’t need to login in the github action ci run.
Example below:
I just saw that it expires in 49 years. What to do by then??? <3 #Y2Kvibes
