Hi @will! I’m trying to to authorize the Yak CLI tool and get the following error:
“This App Can’t run on your PC” - What could be the issue?
Running cmd as admin with Rhino 7.13.21
Do you get the same error if you run it in a normal non-admin CMD or powershell session? Might also be worth repairing your Rhino installation.
A repair did the trick. Thanks @will
