Aligning breps to the extruded segments of the curve
Hi all,
I’m a beginner in Grasshopper and would appreciate your help with a simple script.
There are the breps that have to be oriented to the extruded segments of the curve, but always in the same perpendicular direction to the segments of the curve. The breps on the corners are always turning in the opposite direction. I’ve tried lots of different approaches but haven’t found a solution. If you could please have a look and suggest how to solve it, please I would very appreciate it.
251205_Aligning_segments.gh (11.7 KB)
many thanks
Yaroslava
Set this to False. Your co-linear polylines are Closed, which means they have a string of short segments then one long segment back the other direction to close the loop, which is generating the spurious breps.
Thank you for your help, Tom!
Could I also ask you again to help with the next step? I’m not sure what is missing in the extension of this script to make the breps be within the curve
251205_Aligning_segments(1).gh (18.0 KB)
251205_Aligning_segments a.gh (15.1 KB)
Thank you a lot, Leopoldomonzani:slightly_smiling_face:
