Hello everyone.
I read on the karamba 3D site that you first have to do an Optimise Cross Section to define the height of a concrete slab or wall before doing an OptiReinforcement to determine the reinforcement areas.
" Since the latter is a simplification, one should assure a sufficient height of the concrete cross section by using the “Optimize Cross Section” -component first."
What I understand from the OptiCrossSection of a tile is that you can calculate the minimum thickness so that the utilisation rate does not exceed 1 or another defined value.
If you want to calculate the thickness of the slab you need, neglecting the tense areas (which could become dimensional), I was deliberately going to increase the ftc of the material, to make sure that the dimensioning was only done in the compressed areas.
I understand that these are elastic stress distributions, and that non-linear characteristics have not been taken into account in the design.
1- In your opinion, would this method be appropriate?
Then I recover the thickness found and do an OptimizeReinforcement to find my reinforcement areas :
2 -What do you think of this approach? Despite the fact that it does not take into account the redistribution of forces in the concrete. Can I consider that my utilization rates reflect (more or less) my limit compressive stresses in the concrete (after this second calculation )?
3 - I intend to use this method for walls. For slabs, it doesn’t seem appropriate.
Is there by any chance a way of defining the non-linear behaviour of concrete and the distribution of stresses in concrete as a function of reinforcement?
With Karamba’s tools? Or any ideas on how to do this?
JP text OptiShellReinf_I.gh (78.8 KB)
(I have attached the gh file)
Regards
