Advanced geometry pipeline with VA components by layer
I’m trying to select automatically VA geometries from layer with “advanced geometry pipeline”, but it seem not work with VA components.
Is there a solution or alternative way?
Thank you
Hi @fn_a,
You can reference objects filtering by layer using the VisualARQ Pipeline instead:
Thank you @alfmelbev,
But the layer should be a dynamic input selected from a list (human ui).
Thank you again
Hi @fn_a,
I understand, we will let you know if this is possible at some point. In the meantime, maybe you can do something similar using the VisualARQ API and Rhinocommon.
I am trying to filter wall sublayer layer having the core only, but its not working. Can you please share an example file.
Hi @asisintel you can connect the wall layers that are Core to the “Components” input of the “VisualARQ Explode”, so you get the BReps of those layers only. Find example attached.
Filter Core Wall Layers.gh (9.3 KB)
Perfect. This will really help in daylight simulation model quickly from VA objects. Thanks a lot @fsalla
