I’m sure I’m just not seeing it, but how do I change the size of a texture that I’ve added to a material in Rhino 7? I’m going through my Flamingo materials and saving them as Rhino 7 materials. I seem to recall there was a way to adjust the size in Flamingo, so I expect there would be in Rhino too. In the image below, I would like to make the carbon fiber pattern smaller.
Thanks,
Dan
In Textures, click on the “Carbon Fibre texture sm” - that will give you settings for changing the repetition, rotation and scale of your material
Sash
Hi Sash,
I’m still not seeing an adjustment for scale.
Thanks,
Dan
The number of repetitions will control how big the pattern will be, so if you want it smaller, just tell it to repeat more times
Sash
I see that now. Thanks for your help.
Dan
My pleasure,
There’s a really helpful tutorial on some of the mapping and material workflows for Rhino you might appreciate
Thanks for that link. I will check this out.
