Hi everyone,
is it possible to set individual points when using the command “populate2d/3d points” in grasshopper? Because I want to be able to adjust the points freely.
Other than, do you have an idea how i can cut the spheres i created in half? I couldn’t find a way to do so.
Would appreciate any help!
Thank you in advance!
You can preset a couple of points that will then be part of your random point population by providing them to the components P input.
You can split the a sphere in to two with a plane like this:
thanks for your fast reply, appreciate it!
I actually tried doing so by defining individual points but i don’t get a result somehow…
I can’t quite tell if i just miss something.
You still need to provide a number of points to randomly generate. Currently, your slider is turned off.
I am sorry to bother with basic stuff but i don’t really get what i expect
These are the points I am trying to get but when I provide a number i don’t get the points i want
Hi again,
since i couldn’t solve my problem i tried the maybe “inefficient” way with gumball but now my boundary surface won’t work
Probably because the boundary that should define the surface isn’t planar?
Hello again,
so i solved my problem like that:
Now I just have to split the model in half
Hope I don’t get stuck again at this point
I will try using your approach to split them.
