I’m facing strange behavior when using AddTextDot and AddText. It is only viewable in Front/Left viewport and no text can be seen from perspective/top viewport. I’m using the latest update SR32!
Is it normal and always have been like this or is a bug?
Hello- that certainly looks wrong to me. Can you post a file with one or two of these, or send to tech@mcneel.com?
Hi Pascal, Thanks for reply!
I have sent it via Rhino - Upload to Support to that email address!
Hi -
That looks fine here:
From your screenshot, it looks like the Top and the Perspective viewports are in Shaded
mode, whereas the Front and Left viewports are in Wireframe
. Are the dots visible when you put the Perspective viewport in Wireframe
mode?
Apart from that, please run the Rhino SystemInfo
command and copy-paste the result here.
Yes, you are right. I didn’t know it is only visible in wireframe mode!
Rhino 7 SR32 2023-8-9 (Rhino 7, 7.32.23221.10241, Git hash:master @ 3d9c816c4cd57561d12d8f53246bce304f314ba2)
License type: Commercial, build 2023-08-09
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
- Windows Main Display is laptop's integrated screen or built-in port
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA GeForce GTX 1650 Ti (NVidia) Memory: 4GB, Driver date: 8-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.99
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-4-2023
Driver Version: 31.0.15.3699
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.32.23221.10241
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
Hi -
It isn’t. You have probably changed the settings for the Shaded
display mode. Make sure that Show text
is not unchecked.
Yeah I found that option and it was unchecked! Thank you Wim!
