Adding gps coordinates
Hi all,
Trying to learn new tricks with Rhino. I’ve been working towards designing pumptracks ( Basically a bmx track) and want to be able to draw them up to construction phase.
So I’m wanting to work out how to add gps coordinates within a model in Rhino. So I can setup site layout points etc. Any tips or suggested plugins would be awesome. Been using Lands design so far.!
Pic of what I’m working on.
Site|690x422
export the needed points as coordinates in model-space as text file / .csv … search this forum for a script that does this or use grasshoppers text field save functionality.
import the .csv to excel perform the conversion and add take account of the projects origin.
of course, if you know how to script / programm you can do all this in one step. hope this helps - kind regard -tom
Thanks for the reply, you lost me almost immediately. I was hoping thee was a way within rhino to do it. Maybe using the earthanchorpoint command? Which I tried using but it seems to set it up then disappear. This is all very different to the way I usually use Rhino so forgive my ignorance.
to see a usage of earthanchorpoint
https://wiki.mcneel.com/rhino/flevodam
of course you can also use .kml export (a readable xml) …depends a bit of where you read / process the data…
Hi -
There is nothing in plain Rhino for this, no.
Take a look at the GHowl, Heron, and/or Mosquito plug-ins that have tools to get that done.
Thanks guys will check it out.
