Add text "span count" to _Rebuild command dialog
The _rebuild command currently looks like this when using curves as input:
Could the dialog include the text “span count” (see red text in picture below) as well?
This is already available when using surfaces as input (see picture below), so I do not understand why this should not be included for curves as well.
It should be an easy fix, right? It looks a bit half-finished without the text, to be honest.
Compare the Windows version to the Mac version. Seems like a bug.
Skjermbilde 2024-09-26 kl. 18.36.01
Thanks - I’ve logged the issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-83981
– Dale
RH-83981 is fixed in Rhino 8 Service Release 14 Release Candidate
