Rebuild Rhino 5 vs 6
please advise me with the REBUILD function, I’m already desperate. I was very used to using it in Rhino 5 to simplify curves and surfaces almost constantly. I always set POINT COUNT: 2 and I was sure that a simple single-span curve would be created, the deviation of which I could easily control using the DEGREE size. I’ve always been sure that a single-span curve of quite small order will be created. I have now changed the version to Rhino 6 and REBUILD does not work as before. Maybe REBUILD in Rhino 6 just doesn’t understand, but I often have to set the POINT COUNT number higher than 2 and I always have to try different values ​​for both parameters and I don’t have such easy control over the output and I’m more subordinate to what REBUILD allows. Sometimes I can’t create a single-span object. I know I can use REBUILD CRV NON-UNIFORM, but I don’t work as easily as I did with the classic REBUILD in Rhino 5. I understand that I want stupidity, but there is some possibility to run an old Rebuild from Rhino 5 in Rhino 6. I don’t want to use the old software only for one function, because I think Rhino 6 brings a lot of benefits. Sorry if I want the impossible and I want stupidity. Thanks for the help or for the advice.
If you set the degree to the cp count - 1 then you always get a single span curve. This is a mathematical constraint. Or do I understand you wrong?
Once you have a single span curve you can also call the changedegree command to increase or decrease cp count on a single span geometry, without making it a multispan…
Thanks for the reply. Maybe I gave a bad example, I’m sorry. I have another one here. Before rebuilding I have polycurve in Rhino 5 I am able to simplify it by setting PointCount: 2 Degree: 3. In Rhino 6, nothing is created with the same settings. I would like you to try this example.
Hello - V6 should not allow a point count less than degree + 1 . I cannot get the setting you show on the right; if I ask for two points, the degree immediately goes to 1 as expected, and the point count always goes to degree + 1 at a minimum. In V5, you are not getting what the dialog shows, you are getting the minimum points for a degree 3 curve.
The V6 dialog now shows you what you can have, rather than accept settings that cannot work and give you something different. Does that make sense?
@pascal
Maybe a good idea would be to add a checkbox which allows the user to always get a single span output and only make the pointcount/order tweakable. This would actually prevent the user to set two settings. The V5 tweak was a workaround, which does not work anymore, and which is the complain here. Wouldn’t that be easily fixable? Otherwise a quick script could solve it here…
@nj.artde
You can execute this script in the Python Editor (or by _RunPythonScript yoursavename.py):
crvIds = rs.GetObjects("Please select curves", filter=4)
order = rs.GetInteger("Please set order",3,1,11)
for crvId in crvIds:
    rs.RebuildCurve(crvId,order-1,order)
Hi Tom - That seems like a reasonable idea - a Single Span check box which would auto-adjust point count or degree, depending on which number you tweaked last. I expect if we did this we’d stick with ‘degree’ so as not to introduce a new variable to training and Help…
RH-58239 Rebuild Single span
Thank a lot, I will try it.
